ArcPy: Python Add-In Dialog with Textboxes
With Python Add-In Wizard I created a ButtonTool with which I:
  1. click in the map
  2. get the coordinates of the mouseclick-location in a dialog with textboxes
I want to receive the coordinates in a textbox to have the possibility to copy and paste the coordinate values (e.g. to use them in a document). I get a crash between TKinter and arcpy like I read in some posts before. Nevertheless I want to ask, if anybody has experience with this and has a suggestion.
Here is my code:
Import Tkinterclass ToolCoord(object): def __init__(self): self.enabled = True self.shape = "NONE" self.cursor = 3 def onMouseDownMap(self, x, y, button, shift): pt = arcpy.PointGeometry(arcpy.Point(x,y)) main = Tkinter.Tk() lb = Tkinter.Label(main, text = "UTM-Koordinaten:") lb.pack() t1 = Tkinter.Text(main, width=20, height=0) t1.insert("end", str(x)) t1.pack() t2 = Tkinter.Text(main, width=20, height=0) t2.insert("end", str(y)) t2.pack() main.mainloop()
