R
Rida Azmi
Guest
Landsat 9 data processing
Hello,
In this tutorial, we will see how you can easily manipulate Landsat 9 images in the Google Earth Engine platform.
The goal is to easily display, analyze, calculate spectral indices (like NDVI), geometrically correct and finally export these images.
The access to the storage of Landsat 9 images (like all other images of the Landsat constellation) is through the following link, via the GEE platform.
The link below represents the Landsat 8 image catalog, so for the L9 data, it’s almost the same thing.
https://developers.google.com/earth-engine/datasets/catalog/LANDSAT_LC08_C02_T1_L2
In order to load the image collections in GEE, just type the code below:
A filter is also applied to specify the date and the study area. In our case, we chose the region of Souss Massa whose chief place is the city of Agadir.
A print is applied to see the collection found in the servers for this study area.
print(collection);
The second step is to make a radiometric correction of this collection. For this, we will apply the correction parameters proposed by USGS.
The link below presents the metadata of the RAW data
we will apply a scale factor in order to switch from Digital Number – DN to reflectance data.
Then the function allows applying this calibration
The next step allows going from a collection of images to a single image by applying a “mosaic” type reduction.
Then calculate the vegetation index of this new image and apply an appropriate color palette.
Now it’s time for the display.
It is possible to export these data via Google Drive with the script below
Enjoy !!
Rida AZMI
Data Scientist / Urban Spatial Data
Hello,
كود:
var collection = ee.ImageCollection("LANDSAT/LC09/C02/T1_L2")
.filterDate('2022-02-01','2022-02-19')
.filterBounds(roi);
print(collection);
USGS Landsat 9 Collection 2 Tier 1 and Real-Time data Raw Scenes | Earth Engine Data Catalog | Google Developers
Landsat 9 Collection 2 Tier 1 and Real-Time data DN values, representing scaled, calibrated at-sensor radiance. Landsat scenes with the highest available data quality are placed into Tier 1 and are considered suitable for time-series processing analysis. Tier 1 includes Level-1 Precision Terrain...
كود:
function applyScaleFactors(image) {
var opticalBands = image.select('SR_B.').multiply(0.0000275).add(-0.2);
var thermalBands = image.select('ST_B.*').multiply(0.00341802).add(149.0);
return image.addBands(opticalBands, null, true)
.addBands(thermalBands, null, true);
var dataset = collection.map(applyScaleFactors);The next step allows going from a collection of images to a single image by applying a “mosaic” type reduction.
var image = dataset.mosaic().clip(roi);Then calculate the vegetation index of this new image and apply an appropriate color palette.
كود:
var ndvi = image.normalizedDifference(['SR_B5', 'SR_B4']).rename('NDVI');
var ndviPalette = ['FFFFFF', 'CE7E45', 'DF923D', 'F1B555', 'FCD163', '99B718',
'74A901', '66A000', '529400', '3E8601', '207401', '056201',
'004C00', '023B01', '012E01', '011D01', '011301'];
كود:
var visualization = {
bands: ['SR_B5', 'SR_B4', 'SR_B3'],
min: 0.0,
max: 0.3,
Map.setCenter(-9.57603052720908, 30.406700766638988,7);
Map.addLayer(image, visualization, 'image');
Map.addLayer(ndvi, {min:0, max: 1, palette: ndviPalette}, 'ndvi');
كود:
Export.image.toDrive({
image: ndvi,
description: 'Landsat_raj',
scale: 30,
maxPixels: 10000000000000,
region: roi
Enjoy !!
Rida AZMI
