"XY to Line" not converting all 58,000 records
I have a dbf (and xls) that contains ~58,000 records of latitude and longitude for both start and end points. I would like to connect each XY coordinate pair using the XY to Line tool found inside the Data Management toolbox. I will be using the Great Circle method fyi.
The resultant shapefile contains ~16,000 records/polylines. As far as I can tell, there is no difference between processing the table inside or outside a file geodatabase.
Anyone have any thoughts as to why it may not be processing the entire table? This issue persists with both the dBaseIV and XLS file.
