What is the projection of WGS84 in GIS software?
WGS84 is a reference ellipsoid that determines coordinates of every point on Earth using latitude, longitude and height about the its surface. This ellipsoid is often used as a base to make maps. Though, to make a map on a flat paper or a flat digital screen you need a projection too. An example of a popular projection would be UTM. Mainstream GIS software give plethora of projection alternatives to display your data layers. Among them, they also let you display your data using WGS84 only.My question is: how is that possible? Of course they are using a certain projection but what projection is that? Why they do not tell the user about that?
