First, I would like to apologise for the mistakes. My English is not very good. I read a lot but I don´t find the answer.I'm trying to put a scalebar in a very simple map but the measurement is not correct. I'm going to describe the process (spanis version 2.10.1):
1) I open Qsig -> project -> properties
2) General -> measurement tool WGS84 (SRC transformation connected)
3)SRC on the fly activatec (SRC 3857 and also tried with 4326 similar results)
4) New Shapefile -> line shapefile -> I create a line of 10.000 m length (measured with the qgis measurement tool)
5) Print composer -> new map -> escale ej 1:10.000 -> add scale bar.
6) Export to PDF
7)I print the map (from PDF to printer with pdf not scaled) and the scale with the scalebar and is not correct
Thanks
6) Export to PDF
Thanks
