I'm using a Ublox M8T with a Tallysman antenna which I have used with U-Center 8.818 and have written a ubx file. This ubx file can be taken into RTKLIB v.2.4.2p10 and I can create a nav and obs and a pos file by using the convert button in rtkconv.
There is a nearby ( 2 miles ) continuously operating GPS which is part of the Ordnance Survey's system and the RINEX data can be downloaded with an .15o extension from the OS website.
My workflow with RTKPOST is likely incorrect. In RTKPOST, the RINEX OBS box I has the path to the obs file which was converted from the original .ubx file in RTKCONV. In the RTKPOST UI section with the 3 file path boxes, I have entered the .nav file converted from the original ubx, an ephemeris sp3 file from NASA and the .15o file downloaded from the Ordnance Survey. Regardless of the files I place in the bottom section it doesn't affect the coordinates in the pos file?
