ogr2ogr - extracting S-57 layers
I'm trying to extract the layer DEPARE from an S-57 datafile and convert it into a shapefile. I'm using ogr2ogr from OpenGeo Suite 4.5 (GDAL 1.11.1) on Windows 7 64 bit.
The problem is that when I issue ogr2ogr -f "ESRI shapefile" depare.shp US6RI26M.000 DEPARE I get an error FAILURE: Couldn't fetch requested layer 'DEPARE'!.
This seems odd because when I load the same s-57 file into QGis I can choose the layer DEPARE among all other layers. I've tried calling ogrinfo -ro -summary US6RI26M.000 which returns the follwing:
INFO: Open of `US6RI26M.000' using driver `S57' successful.1: DSID (None)2: Point (Point)3: Line (Line String)4: Area (Polygon)5: Meta (None)I struggle to understand why I don't see the same layers that I get when opening the file in QGis - DISD, BRIDGE, BUISGL, BUAARE, CTNARE, DEPARE... Is the DEPARE layer part of a higher-level layer 4: Area (Polygon) as shown by ogrinfo?
Question: How can I extract the DEPARE layer from an S-57 file and convert it into a shapefile using the ogr2ogr tool?
I'm clearly missing something. I've searched for related q&a but none I've found so far solves my problem.
