I'm following the Tutorial directions and I've tried some alternative approaches but PyScripter keeps coming back with the exception message: Process did not complete.
try: #Import Python modules import arcpy from arcpy import env #Set the workspace environment env.workspace = r"C:\GISTutorial_for_PyScripting\GISTPython\Data\City of Oleander.gdb" #ENTER CODE arcpy.Union_analysis(in_features="Parcels #;ZoningDistricts #", out_feature_class="C:/GISTutorial_for_PyScripting/GISTPython/MyExercises/MyAnswers.gdb/UnionTemp", join_attributes="ALL", cluster_tolerance="#", gaps="GAPS") # Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script # The following inputs are layers or table views: "UnionTemp" arcpy.Select_analysis(in_features=r"C:/GISTutorial_for_PyScripting/GISTPython/MyExercises/MyAnswers.gdb/UnionTemp", out_feature_class=r"C:/GISTutorial_for_PyScripting/GISTPython/MyExercises/MyAnswers.gdb/UnionFinal", where_clause="FID_ZoningDistricts -1") #Delete TempUnion file from geodb # Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script # The following inputs are layers or table views: "UnionTemp" arcpy.Delete_management(in_data="C:/GISTutorial_for_PyScripting/GISTPython/MyExercises/MyAnswers.gdb/UnionTemp", data_type="FeatureClass") #Determine Results print "New feature class has been created"except: print "Process did not complete"
