ISIS to GDAL to QGIS: Georeferencing Mars Images
I'm trying to use QGIS to view some images from the Mars Reconnaissance Orbiter Context Camera. I use ISIS3 to download the images and convert them to mapped .cub files, following the instructions here: http://isis.astrogeology.usgs.gov/I...ing_with_Mars_Reconnaissance_Orbiter_CTX_Data
Now I'm trying to export these ISIS cube files to GTiff files, to view in QGIS, I can do this but the georeferencing doesn't seem to work. I've tried this in 3 different ways:
  1. Use the ISIS command isis2std to generate tif (and tfw) files.
    When I try to open the tif file in QGIS it asks me to choose a projection type (side question, is there a suitable projection for Mars? I always choose WGS 84, stupid I know but I don't know a more sensible option). Then once the raster is loaded it automatically displays as a grayscale image but my coordinates are not in degrees, they appear to be in pixels and have a range of 100s of thousands.
    This method produces a tif image of ~100 Mb from an original .cub of close to 1 Gb.
  2. Use gdal: gdal_translate -of GTiff input_mapped.cub output.tif.
    This time I don't get asked to choose a projection type. The projection takes on 'USER:100002'. Hopefully this means that it is managing to read the appropriate Mars projection from the ISIS cub? The image displays as a solid grey box in grey scale this time, but I can see details by switching to a different colour mapping scheme. Again though my coordinates are not in degrees, they range in the hundreds of thousands again.
    This method produces a GTiff with the same ~1 Gb size as the original .cub image.
  3. Open the ISIS .cub file directly in QGIS.
    Has basically the same effect as for method 2.
Because of the file sizes I'd prefer a variation of method 1, but with a suitable projection and georeferencing scheme for Mars.
Edit: Here is the georeference, and the output of gdalinfo on the original ISIS .cub file:
georeference (in python):
>>>import gdal>>>from gdalconst import *>>>fn = 'P01_001356_1747_XN_05S221W.map.cub'>>>ds = gdal.Open(fn, GA_ReadOnly)>>>gt = ds.GetGeoTransform()>>>gt(-22085.510544416, 5.1698292472885, 0.0, -234679.22885141, 0.0, -5.1698292472885)gdalinfo (from terminal):
$gdalinfo file.cubDriver: ISIS3/USGS Astrogeology ISIS cube (Version 3)Files: P01_001356_1747_XN_05S221W.map.cub P01_001356_1747_XN_05S221W.map.cub.aux.xmlSize is 8526, 30111Coordinate System is:pROJCS["Sinusoidal Mars", GEOGCS["GCS_Mars", DATUM["D_Mars", SPHEROID["Mars",3396190,0]], PRIMEM["Reference_Meridian",0], UNIT["degree",0.0174532925199433]], PROJECTION["Sinusoidal"], PARAMETER["longitude_of_center",138.45730511261], PARAMETER["false_easting",0], PARAMETER["false_northing",0]]Origin = (-22085.510544415999902,-234679.228851410007337)Pixel Size = (5.169829247288500,-5.169829247288500)Corner Coordinates:Upper Left ( -22085.511, -234679.229) (138d 5' 1.74"E, 3d57'33.05"S)Lower Left ( -22085.511, -390347.957) (138d 4'56.04"E, 6d35' 7.46"S)Upper Right ( 21992.454, -234679.229) (138d49'45.19"E, 3d57'33.05"S)Lower Right ( 21992.454, -390347.957) (138d49'50.86"E, 6d35' 7.46"S)Center ( -46.528, -312513.593) (138d27'23.46"E, 5d16'20.26"S)Band 1 Block=406x128 Type=Float32, ColorInterp=Undefined Min=0.033 Max=0.150 Minimum=0.033, Maximum=0.150, Mean=0.080, StdDev=0.020 NoData Value=-3.40282265508890445e+38 Metadata: STATISTICS_MAXIMUM=0.15037615597248 STATISTICS_MEAN=0.080181184414784 STATISTICS_MINIMUM=0.033307410776615 STATISTICS_STDDEV=0.020299974127104
