I'm just trying to replicate this example but using a different account (libregis), using a raster table called foto_pnoa, created just dropping a tif file when creating a new dataset. And I'm getting this error
{"errors":["Postgis Plugin: ERROR: invalid input syntax for type double precision: \"76.4293851819992 ,10\"\nCONTEXT: SQL function \"_raster_constraint_info_scale\" statement 1\n\nin executeQuery Full sql was: 'select r.r_table_schema sch, r.r_table_name tab, r.r_raster_column col, greatest(abs(r.scale_x ), abs(r.scale_y)) scl from raster_overviews o, raster_columns r where o.r_table_schema = 'public' and o.r_table_name = 'foto_pnoa' and o.r_raster_column = 'the_raster_webmercator' and r.r_table_schema = o.o_table_schema and r.r_table_name = o.o_table_name and r.r_raster_column = o.o_raster_column ORDER BY scl ASC'\n encountered during parsing of layer 'layer0' in Layer"]}
when sending a POST request to http://libregis.cartodb.com/api/v1/map, using this as POST body (map config)
{"version":"1.3.1","layers":[{"type":"cartodb","options":{"sql":"select * from foto_pnoa","cartocss":"#foto_pnoa {raster-opacity: 0.5;}","cartocss_version":"2.3.0","geom_column":"the_raster_webmercator","geom_type":"raster"}}]}
