I am trying to import a dataset generated by my local council (Turin, Italy).
The data appears on the map but it's slightly shifted and it doesn't match the Open Street map layer that CartoDB uses as a default.
Is there any way I can easily convert all my datasets to match CartoDB standards? By opening the .prj file I have it looks like I am using Monte Mario reference system.. This is what is says:
PROJCS["Monte_Mario_Italy_1",GEOGCS["GCS_Monte_Mario",DATUM["D_Monte_Mario",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",1500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",9.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0],AUTHORITY["EPSG",3003]]
Thanks! Tom
Thanks! Tom
