How to use pythons' GeoAlchemy2 to filter on dynamically generated Points?
I'm trying to do something like this SQL query in Geoalchemy2:
SELECT district_polygons.district FROM markers, district_polygons WHERE ST_Contains(district_polygons.multi_poly, Point(markers.marker_long, markers.marker_lat))This query works great as is in MySQL. This shows me which district each marker is in.
I want to replicate something like this using Geoalchemy2 / SQLAlchemy. This is the what I tried:
results = dbSession.query(District_Polygon.district).\ filter(func.ST_Contains(District_Polygon.multi_poly, WKTElement('POINT({0} {1})'.format(Marker.marker_long, Marker.marker_lat)))).all()Unfortunately the formatter isn't working, and sqlalchemy output looks like this:
SELECT district_polygons.district AS district_polygons.districtFROM markers, district_polygonsWHERE ST_Contains(district_polygons.multi_poly, ST_GeomFromText(%s))INFO sqlalchemy.engine.base.Engine ('POINT(markers.marker_long markers.marker_lat)')[]How can I replicate the functionality of the SQL command in the ORM model of Geoalchemy / SQLAlchemy? I'd like to avoid raw SQL if I can.
