i want to select the (Sumava) from the attribute table and then make a shape file, my problem is i don't know which function should i use to select this area.if any one can help me?
import ogr import os direction_parks = 'ArcCR500_v32/ChranenaUzemi.shp' direction_result = 'ArcCR500_v32/result.shp' open_parks = ogr.Open(direction_parks) layer_park = open_parks.GetLayer(0) layer_park.SetAttributeFilter("???????") number_park = layer_park.GetFeatureCount() driver = ogr.GetDriverByName("ESRI shapefile") if os.path.exists(direction_result): driver.DeleteDataSource(direction_result) dataset = driver.CreateDataSource(direction_result) new_layer = dataset.CreateLayer(direction_result, geom_type= ogr.wkbPolygon) number = 0 for j in range(0, number_park): h = layer_park.GetNextFeature() h_geometry = h.GetGeometryRef() new_layer.CreateFeature(h) dataset.Destroy()
