I'm using ArcMap 10.3.
I have a layer of different land use types. I found out that many polygons overlap each other and as a result the same polygon have two different land use types.
Thanks to @radouxju's answer, I built a topology for the land use layer (with the mustn't overlap rule). Then, I used merge to fix the large overlapping polygons.
However, I have thousands of small overlapping polygons. I can fix all of them manually which will be time taking.
Could you please let me know if there is a faster way to fix all these errors?
Update
You can find the land use layer here https://goo.gl/0aE3wq
Update
