How to attach attribute table to new shapefile using OGR?
i have made a new shapefile from the original shapefile , and now i want to copy the attribute table from the original shapefile to the new select shapefile , but i don't know how to do that?
import ogr,os,sys,ogr Datasource_Parks = 'ArcCR500_v32/ChranenaUzemi.shp' Direction_Result_Shp = 'ArcCR500_v32/Result.shp' Direction_Result_Dbf="ArcCR500_v32/Table.dbf" Open_Parks = ogr.Open(Datasource_Parks) layer_park = Open_Parks.GetLayer(0) SQL = "NAZEV_ASCI = 'Krkonossky narodni park'" layer_park.SetAttributeFilter(SQL) Number_Of_Park = layer_park.GetFeatureCount() Driver = ogr.GetDriverByName("ESRI shapefile") if os.path.exists(Direction_Result_Shp): Driver.DeleteDataSource(Direction_Result_Shp) Dataset = Driver.CreateDataSource(Direction_Result_Shp) New_Layer = Dataset.CreateLayer(Direction_Result_Shp, geom_type= ogr.wkbPolygon) number = 0 for i in range(0, Number_Of_Park): H = layer_park.GetNextFeature() H_geometry = H.GetGeometryRef() New_Layer.CreateFeature(H) Dataset.Destroy()
<a href="http://i.stack.imgur.com/2xZLo.jpg" rel="nofollow">
