Normally consultants (LiDAR survey) provide me with data to my specifications; already in ESRI GRID or ASCII GRID format. This way LiDAR data can be easily used with ArcGIS.This time I only have xyz files (i.e., with regular spaced xy coordinates). Previously I would use a utility by Min-Lang Huang named GridBatch that would convert XYZ to ASCII GRID then to ESRI GRID files. Unfortunately the utility is crashing since i upgraded my machine to W7 64bit and ArcGIS to version 10.
Is there another way to batch convert LiDAR XYZ data to ESRI GRID files?
(Convert to points -> Interpolate is an option I would like to avoid considering there are 300+ tiles to convert)
