I'm trying to create a python script tool that will take in a DEM/raster as a parameter, pull out the maximum and minimum elevation values, and iterate through this range of values at a specified counting interval.
This script outputs the resulting raster masks to an output geodatabase, as another parameter. I keep getting the error '000865: Input Raster: inDEM does not exist' when I try to run my script tool. I'd like help resolving this issue in my code, as I'm not sure what the cause is.
import arcpyfrom arcpy.sa import *import osarcpy.CheckOutExtension("Spatial")arcpy.env.overwriteOutput = TrueinDEM = arcpy.GetParameterAsText(0)intervalElevation = int(arcpy.GetParameterAsText(1))outGDB = arcpy.GetParameterAsText(2)elevMinResult = arcpy.GetRasterProperties_management("inDEM", "MINIMUM")elevMaxResult = arcpy.GetRasterProperties_management("inDEM", "MAXIMUM")minElevation = elevMinResult.getOutput(0)maxElevation = elevMaxResult.getOutput(0)myElevations = range(minElevation, maxElevation, intervalElevation)for elev in myElevations: outDEM = os.path.join(outGDB, "lessthan" + str(elev)) outLessThan = LessThan(inDEM, elev) outLessThan.save(outDEM) print "Finished " + outDEM
