I'm trying to get a WebMap object (as JSON) from a JavaScript Map object in the ArcGIS JavaScript API. Is there any way to do this within the API, without using ArcGIS.com? Ideally something like:
var webMapAsJSON = map.toWebMap();From the "Export Web Map Task" documentation in the REST API(http://sampleserver6.arcgisonline.c...es/PrintingTools/GPServer/Export Web Map Task), there's this line that suggests it should exist:
"The ArcGIS web APIs (for JavaScript, Flex, Silverlight, etc.) allow developers to easily get this JSON string from the map."
However, I don't see anything in the Map object or elsewhere in the API that would do this. Any ideas? Thanks.
