I am trying to geo-reference an image using gdal_translate in a command prompt. Currently I have the following
gdal_translate.exe -of GTiff -a_nodata 0 --config GDAL_DATA "Config location" -a_ullr -77.057275 38.872024 -77.054672 38.869986 -a_srs EPSG:3857 "Input.tif" "Output.tif"Where the config location is the location of the gdal data files.
The issue I am having is when I open the image it has lost its aspect ratio. I believe it has something to do with the projection but I am unsure.
gdalinfo.exe gives the following info.
Driver: GTiff/GeoTIFFFiles: C:\Users\monke\Desktop\Trial\Temp\Random Project GeoReferenced.tifSize is 1950, 1950Coordinate System is
ROJCS["WGS 84 / Pseudo-Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS 84",6378137,298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433], AUTHORITY["EPSG","4326"]], PROJECTION["Mercator_1SP"], PARAMETER["central_meridian",0], PARAMETER["scale_factor",1], PARAMETER["false_easting",0], PARAMETER["false_northing",0], UNIT["metre",1, AUTHORITY["EPSG","9001"]], EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs"], AUTHORITY["EPSG","3857"]]Origin = (-77.057275000000004,38.872024000000003)Pixel Size = (0.000001334871795,-0.000001045128205)Metadata: AREA_OR_POINT=Area TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch) TIFFTAG_SOFTWARE=TwelveMonkeys ImageIO TIFF writer DEV TIFFTAG_XRESOLUTION=72 TIFFTAG_YRESOLUTION=72Image Structure Metadata: INTERLEAVE=PIXELCorner Coordinates:Upper Left ( -77.0572750, 38.8720240) ( 0d 0' 2.49"W, 0d 0' 1.26"N)Lower Left ( -77.0572750, 38.8699860) ( 0d 0' 2.49"W, 0d 0' 1.26"N)Upper Right ( -77.0546720, 38.8720240) ( 0d 0' 2.49"W, 0d 0' 1.26"N)Lower Right ( -77.0546720, 38.8699860) ( 0d 0' 2.49"W, 0d 0' 1.26"N)Center ( -77.0559735, 38.8710050) ( 0d 0' 2.49"W, 0d 0' 1.26"N)Band 1 Block=1950x1 Type=Byte, ColorInterp=Red NoData Value=0Band 2 Block=1950x1 Type=Byte, ColorInterp=Green NoData Value=0Band 3 Block=1950x1 Type=Byte, ColorInterp=Blue NoData Value=0Thanks in advance for anyone who can shed some light on this.
