I encountered this error when trying to publish a map service to an ArcGIS Server 10.1 (installed on linux).
Other info: The geodatabase is registered with the server. And it did work in the past. We use a PostgreSQL gdb server.
Thank you for any help.
--------------------------- Service Publishing Result --------------------------- Packaging succeeded, but publishing failed.
ERROR 001359: Failed to connect to the server.
Please consult the GP Results Window for enhanced error description
.ERROR 001359: Failed to connect to the server.
