I need to digitize a bunch of islands from imagery in QGIS. It is the Bing Maps aerial imagery layer. I will obtain all required permissions. My plan is to lock the map scale at 1:25,000 and use heads up digitizing. If it matters I am on the equator.
Assume I do the best job I can do digitizing. I can tell from features I can depict in the map that the imagery is far less than 12.5 m resolution which according to Tobler (table below) would be required to make the 1:25,000 claim. For example, I know from field visits those lakeside umbrellas are only ~2 m in diameter, some of those dirt trails are only ~2 m wide, and the dock is only ~ 1 m wide.
I used the basic Tobler equation below to state that at 2 m resolution (assuming 1 pixel to one cell) I can claim that my scale would be 1:4,000.
I think I am good on (1) as when I lock the scale at 25,000 I can still see clearly depict features far below 12.5 m on the ground, for example, some of the white line widths on the image below.
In many ways it is the opposite of this question. Digitized Map To Scale
Similarly, if you need to find out the mapping scale from a known imagery resolution you can do so using the formula below: Map Scale = Raster resolution (in meters) * 2 * 1000.
So, if I digitized at one pixel per cell I could make the claim than my map scale was at least 1:4000 but what claim can I make if I set the scale of the map to 1:25,000? My concerns are:
- Background pyramids serving up a resolution that goes beyond 12.5 m.
- The system used by QGIS to "chuck" cells onto pixels.
