Code to get featureclass name from existing topology
I am creating and validating topology through vb.net and arcobject code.Things are running fine as I am able to add rule and validate it . Problem is when once the program is run and topology is created.Second time when i am running my code , I have written that if topology exist then delete it and create new topology.But I observed that deleting topology every time will corrupt memory.
So Second approach I used is to first delete rule in the existing topology and then featureclass from it and not the topology.
Then new rule and featureclasses are added to same existing topology. But the problem is I am not able to get the featureclass name in the existing topology. How can I get the name of feature class participated in topology?
The code is as follows-:
If pdataset.type=esridatasettype.featureclass then Dim fcnme as string Dim fcarray as Arraylist=New Arraylist fcnme=pdataset.name fcarray.add(fcnme) for i as integer=0 to fcarray.count-1 pname=fcarray.item(i).tostring Dim gp as Geoprocessor=New geoprocessor Dim removefc as DataManagementTool.RemoveFeatureclassFromtopology=New DataManagementTool.RemoveFeatureclassFromtopology removefc.in_topology=topologyname removefc.in_featureclassnme=pname Dim sv as object=nothing try GP.execute(removefc,nothing) Catch ex as exception end try
