CARTOSAT-1 SATELLITE SENSOR
CARTOSAT-1 is a state-of-the-art remote sensing satellite built by ISRO (Indian Space Research Organization) which is mainly intended for cartographic applications in India. The 1560 kg satellite was launched by the PSLV on May 5, 2005 from the newly built second launch pad at Sriharikota, and is the eleventh satellite to be built in the Indian Remote Sensing (IRS) satellite series. Weighing 1560 kg at lift-off, CARTOSAT-1 is launched into a 618 km high polar Sun Synchronous Orbit (SSO) by PSLV-C6.
Source and Image Credit: ISRO
CARTOSAT-1 carries two panchromatic cameras that take black-and-white stereoscopic pictures in the visible region of the electromagnetic spectrum. The satellite images have a spatial resolution of 2.5 meter and cover a swath of 30 km. The cameras are mounted on the satellite in such a way that near simultaneous imaging of the same area from two different angles is possible. This facilitates the generation of accurate three-dimensional maps. The cameras maneuver across the direction of the satellite's movement to facilitate the imaging of an area more frequently. The images taken by CARTOSAT-1 cameras are compressed, encrypted, formatted and transmitted to the ground stations.
CARTOSAT-1 also carries a Solid State Recorder with a capacity of 120 Giga Bits to store the images taken by its cameras. The stored images can be transmitted when the satellite comes within the visibility zone of a ground station.
After its separation from the fourth stage of PSLV, CARTOSAT-1 is made to accurately point towards the earth through a series of complex maneuvers. This is followed by a thorough checkout of the satellite, switching on the cameras and fine tuning of the orbit.
CARTOSAT-1 SATELLITE SENSOR SPECIFICATIONS
Resolution 2.5m
Launch Date May 5, 2005
Launch Location Sriharikota, India
Nominal Altitude 617.99 km
Orbits Per Day 15
Orbital Repeat Cycle 116 days
Nominal Wait Time to Acquire Adj.Path 11 days
Max. Wait Time for Revisit 5 days
Node for P/L Operations Descending Node
Local Time for Equatorial Crossing 10:30 AM
Orbital Parameters
Semi-major axis 6996.128 km
Eccentricity 0.001
Inclination 97.87 degrees
CARTOSAT-1 MAPPING APPLICATIONS
With improved spatial resolution and stereo imaging capability it will enable the generation of Digital Elevation Models (DEM) and other value added products. The data from CARTOSAT-1 is expected to provide enhanced inputs for large scale mapping applications and stimulate newer applications in the urban and rural development, land and water resources management, disaster assessment, land cover change detection, relief planning and management, environmental impact assessment and various other Geographical Information Systems (GIS) applications.
CARTOSAT-1 SATELLITE IMAGE GALLERY
Please visit our CARTOSAT-1 Image Gallery for sample images.
