I was tasked to create a layer with the flooded areas if the sea / river level was to go up by X feet. There is no requirement to take Flow and Pour Points into account, just a simple raise in water level.I will be using ArcGIS and have access to all extensions. As an input I have a DTM (tiff) and coastline (shp) layers.I have found this very helpful video as a reference, which outlines the following process:
Is it indeed the case? Which tool would be the best for that?
- Calculate
- Reclassify to have only a single value
- Convert to vector
- Remove polygons that are not touching the coastline (select by location)
