We just launched geocoding autocomplete, delivering a dramatically better geocoding experience. You’ve probably seen autocomplete before when searching a map: as you type in a city name, like Washington DC, the search returns possible matches, saving you the trouble of writing your entire query. That’s autocomplete.
This is possible thanks to several upgrades to our geocoder:
To evaluate autocomplete performance, a portion of an input query is sent multiple times, adding one more character with each iteration, until the expected result is at the top of the returned suggestions. The fewer iterations a given query requires, the better the result. Here’s a sample of how a test run looks:
Lubbock United States (3 chars)--+North Adams United States (8 chars)-------+Poway United States (4 chars)--=+Santa Ana United States (7 chars)------+Toledo United States (8 chars)--=====+6.4 avg chars to match4.7 avg chars to first relevant suggestionIn this example, it only takes 3 characters Lub to get to Lubbock USA. Queries that match more results like Toledo require more context (the = means the result is one of the suggestions but not the top result).
Proximity mode
Autocomplete suggestions can be made more accurately when proximity bias is enabled. There are a lot of 1308 W Main’s in the world. Without more context there’s really no way to guess the right result at 10 characters.
Testing without location bias
Mapbox# 1308 W Main St Yadkinville (17 chars)# ----------------+Without location bias, it takes an average of 45% more characters to deliver the correct suggestion. Using proximity signals can deliver a big improvement to users' experience.
Try it out
Autocomplete and proximity mode are now usable through both mapbox.js and react-geocoder.
Or, if you want to give the functionality a try without writing any Javascript, you can use the demo below:
View full-screen demo
What’s next
This work required a huge refactor of our core geocoder. With this framework in place, we can turn our focus to incremental improvements and expanded coverage. Coming up:
- Autocomplete support in our data structures
- A proximity option (aka “helicopter mode”) that prioritizes results in the area being viewed
- And lots and lots of tests.
Proximity mode
Try it out
What’s next
- Expanded global coverage
- Better result prioritization
- Support for points of interest
- Speed and precision improvements
