تاريخ الإعلان عنها: 2012-02-20
مطلوب مساح Field Specialist – Land Surveyor بالكويت
تفاصيل الوظيفة
مكان الوظيفة: الكويت, الكويت
قطاع الشركة: البناء و الهندسه المدنيه
طبيعة عمل الشركة: صاحب عمل (القطاع الخاص)
الدور الوظيفي:الهندسة
الحالة الوظيفية: دوام كامل
نوع التوظيف:موظف
عدد الوظائف الشاغرة: 1 المرشح المفضل
المستوى المهني:متوسط الخبرة
الشهادة:دبلوم
Kharafi National KSC (Closed)
MAIN PURPOSE OF JOB
To take measurements and determine property / work boundaries and to provide data relevant to the shape, location, elevation or dimension of land for Engineering, construction or other purposes
JOB OBJECTIVES
1. To calculate heights, depths, relative positions, distances, and other characteristics of the terrain to perform a work activity.
2. To compute geodetic measurements and interpret survey data in order to determine positions, shapes and elevations of topographic features.
3. To establish fixed points for use in making maps, using geodetic and engineering instruments.
4. To sketch the path above a surface area, following any excavation work.
5. To prepare and maintain sketches, maps, reports and legal descriptions of surveys in order to certify and assume liability for work performed.
6. To coordinate report findings with engineers and architectural personnel, clients, and others parties involved with the projects.
7. To prepare / supervise preparation of all data, charts, records, etc and to record the results of land surveys and features.
8. To verify the accuracy of survey data, including measurements and calculations conducted at various sites.
• Should have adequate experience in MEW Water Projects
المهارات
ESSENTIAL WORK ACTIVITIES
• Collecting Information
• Estimating / Evaluating
• Info from / Using instruments
• Administrating / Writing / Drawing
• Calculating / Counting
• Checking objects / Work/ / Procedures
• Checking written info / Designs
•Relationships / Representing / Enquiring
الخلفية التعليمية
Diploma in Civil Engineering
وصف الشركة
KHARAFI NATIONAL is a leading Infrastructure Project Developer in water, wastewater treatment and reclamation, district cooling, solid waste management and enhanced oil recovery as well as a leading Contractor and Facilities Management Service Provider to the petroleum, chemicals, power, water and commercial sectors in the Middle East and Africa.
As Infrastructure Project Developer, we are pursuing projects on a BOT, BOO or PPP basis.
Our commitment to excellence has made Kharafi National the regional most successful Infrastructure Project Developer and with an undisputed reputation for quality. The company’s client list includes some of the most prestigious corporations in the region.
Since it was established in 1976 Kharafi National has developed from a local contracting company into a world-class pan-Arabian Infrastructure Project Developer capable to undertake a wide range of challenging projects.
Today Kharafi National is an international, multi-disciplined Company with diversified operations in:
Infrastructure Project Development
EPCM
Construction
Fabrication Services
Kharafi National’s multi-faceted organization contains all the disciplines - civil, HVAC, mechanical and electrical engineering, etc.- required to deliver a broad range of development and contracting services to the petroleum, chemical, power, water and commercial industries in the Middle East and Africa.
Kharafi National now has:
an annual turnover approaching US$1 billion;
a multi-national workforce of over 25,000, of whom some 10% are managers, engineers, superintendents, technical and clerical staff;
a fleet of company-owned heavy construction equipment exceeding 3,500 units;
its own fabrication facilities for piping, structural steel, pressure vessels, skids and packages that meet ASME standards;
Kharafi National is an ISO 9000:2000 company and operates in full compliance with ISO quality assurance systems and procedures.
أصل الاعلان والتقديم:
http://kfupm.bayt.com/ar/job/?xid=1755992
او
jobs@kharafinational.com
تحياتي
تفاصيل الوظيفة
نوع التوظيف:موظف
الشهادة:دبلوم
MAIN PURPOSE OF JOB
JOB OBJECTIVES
المهارات
الخلفية التعليمية
وصف الشركة
EPCM
Construction
او
تحياتي
