I am able to add shapefiles with less than 1000 points by using the ArcGIS Portal REST API as shown in this example: https://developers.arcgis.com/javasc...shapefile.html
However, there is a 1000 point maxRecordCount through their service. I have tried setting the maxRecordCount in the publishParameters without any luck. I also thought it may be possible to publish our own service with a raised maxRecordCount, but I am not very experienced in publishing custom scripts and did not know whether there was a toolbox that already provided this functionality.
So my question is, is there a way to use the ArcGIS Portal REST API to return more than 1000 records? If not, what would be the best approach to solve this problem?
