مصر العراق السعودية سوريا لبنان الأردن اليمن ليبيا السودان المغرب تونس الكويت الجزائر البحرين الإمارات عمان موريتانيا الصومال فلسطين جيبوتي جزر القمر قطر باكستان اندونيسيا تركيا ايران ماليزيا
  • amazing_sunset
  • apple_tree
  • beutiful_landscape
  • birch
  • camomiles
  • cherry
  • in_the_forest
  • nature
  • spoondrift
  • stream
  • strobiles_on_spruce
  • sun_and_sea
  • jquery carousel
  • sunset_on_the_river
amazing_sunset1 apple_tree2 beutiful_landscape3 birch4 camomiles5 cherry6 in_the_forest7 nature8 spoondrift9 stream10 strobiles_on_spruce11 sun_and_sea12 sunset13 sunset_on_the_river14
slider html5 by WOWSlider.com v8.2
النتائج 1 إلى 2 من 2
  1. #1
    عضو مؤسس
    تاريخ التسجيل
    Jun 2011
    المشاركات
    62,789
    Post Landsat 7
    LANDSAT 7 +ETM SATELLITE IMAGERY
    Satellite Imaging Corporation acquires LANDSAT 7 satellite imagery worldwide.
    HISTORY OF LANDSAT 7 +ETM
    LANDSAT-1 was the world's first earth observation satellite (EOS), launched by the United States in 1972. It is recognized for its ability to observe the earth far from space. Its excellent set of capabilities emphasized the importance of state-of-the-art remote sensing. Following LANDSAT-1, LANDSAT-2, 3, 4, 5, and 7 were launched. LANDSAT-7 is currently operated as a primary satellite.
    LANDSAT-5 was equipped with a multispectral scanner (MSS) and thematic mapper (TM). MSS is an optical sensor designed to observe solar radiation, which is reflected from the Earth's surface in four different spectral bands, using a combination of the optical system and the sensor. TM is a more advanced version of the observation equipment used in the MSS, which observes the Earth's surface in seven spectral bands that range from visible to thermal infrared regions.
    LANDSAT SATELLITE SENSOR CHARACTERISTICS
    Launch Date 15 April 1999, at Vandenberg Air Force Base in California
    Spatial Resolution 30 meters
    Orbit 705 +/- 5 km (at the equator) sun-synchronous
    Orbit Inclination 98.2 +/- 0.15
    Orbit Period 98.9 minutes
    Grounding Track Repeat Cycle 16 days (233 orbits)
    Resolution 15 to 90 meters
    The thematic mapper (TM) is an advanced, multispectral scanning, earth resources sensor designed to achieve higher image resolution, sharper spectral separation, improved geometric fidelity, and greater radiometric accuracy and resolution than that of the MSS sensor. This sensor also images a swath that is 185 km (115 miles) wide, but each pixel in a TM scene represents a 30 m x 30 m ground area, except in the case of the far-infrared band 7, which uses a larger 120 m x 120 m pixel. The TM sensor has seven bands that simultaneously record reflected or emitted radiation from the Earth's surface in the blue-green (band 1), green (band 2), red (band 3), near-infrared (band 4), mid-infrared (bands 5 and 7), and the far-infrared (band 6) portions of the electromagnetic spectrum. TM band 2 can detect green reflectance from healthy vegetation, and band 3 is designed for detecting chlorophyll absorption in vegetation. TM band 4 is ideal for near-infrared reflectance peaks in healthy green vegetation, and for detecting water-land interfaces. TM band 1 can penetrate water for bathymetric (water depth) mapping along coastal areas, and is useful for soil-vegetation differentiation, as well as distinguishing forest types. The two mid-infrared bands on TM are useful for vegetation and soil moisture studies, and discriminating between rock and mineral types. The far-infrared band on TM is designed to assist in thermal mapping, and for soil moisture and vegetation studies.
    The LANDSAT-7 satellite was successfully launched from Vandenburg Air Force Base on April 15, 1999. LANDSAT-7 is a 5,000 pound-class satellite, designed for a 705 km, sun-synchronous, earth mapping orbit with a 16-day repeat cycle. The payload is a single nadir-pointing instrument, the Enhanced Thematic Mapper Plus (ETM+). S-Band is used for commanding and housekeeping telemetry operations, while X-Band is used for instrument data downlink. A 378 gigabit solid state recorder (SSR) can hold 42 minutes of instrument data and 29 hours of housekeeping telemetry concurrently.
    LANDSAT-7 is equipped with Enhanced Thematic Mapper Plus (ETM+), the successor of TM. The observation bands are essentially the same seven bands as TM, and the newly added panchromatic band 8, with a high resolution of 15m was added. An instrument malfunction occurred on May 31, 2003, with the result that all Landsat 7 scenes acquired since July 14, 2003 have been collected in *quot;SLC-off*quot; mode (Details).
    Systematic Correction (Level 1G) Gap-filled (SLC-off only) includes radiometric correction, geometric correction, and replacement of all missing image pixels within the SLC-off (*quot;primary*quot;) cene with estimated values based on histogram-matched data from one or more user-defined *quot;fill*quot; scenes acquired on a separate date. The image will be rotated and aligned to a user-specified projection. A scan gap mask is included with the final product. All Level 1G SLC-off gap-filled products are processed by the Level 1 Product Generation System (LPGS).
    ARCHIVED AND NEW LANDSAT IMAGERY
    For many image requests, a matching image can be located in our global archives of LANDSAT 7 imagery. If no image data is available in the archives, new LANDSAT 7 satellite image data can be acquired through a satellite tasking process. Besides providing image data, Satellite Imaging Corporation performs many tasks in the background to ensure that we meet customer specifications and time schedules. We:
    Negotiate the attainment of images
    Process imagery, including orthorectification, DSMs, DTMs, and raster-to-vector conversions
    Provide 3D terrain visualization and modeling for project planning and support
    Incorporate third-party USA and international GIS data
    Consult on band combinations most appropriate to bring out the geographical and manmade features that are most pertinent to your project
    Perform spectral analysis for land cover use classifications and environmental changes
    LANDSAT data has been used by government, commercial, industrial, civilian, and educational communities throughout the world. The data is used to support a wide range of applications in such areas as global change research, agriculture, forestry, geology, resource management, geography, mapping, hydrology, and oceanography. The images can be used to map anthropogenic and natural changes on the Earth over periods of several months to two decades. The types of changes that can be identified include agricultural development, deforestation, desertification, natural disasters, urbanization, and the development and degradation of water resources.
    For more information and pricing, please contact us.
    LANDSAT SATELLITE IMAGERY GALLERY
    For LANDSAT sample images, please visit our LANDSAT gallery.
  2. #2
    عضو جديد
    تاريخ التسجيل
    Apr 2014
    المشاركات
    10
    GIS Tenders
    How can I save my area from ( http://earthexplorer.usgs.gov/ )
    and I need to coordinate for my work space ?
    Thank for answer me ^_^ *gt;
معلومات الموضوع
الأعضاء الذين يشاهدون هذا الموضوع
الذين يشاهدون الموضوع الآن: 1 (0 من الأعضاء و 1 زائر)
المواضيع المتشابهه
  1. القمر الصناعي Landsat 8
    بواسطة المشرف العام في المنتدى مستشعرات الأقمار الصناعية
    مشاركات: 4
    آخر مشاركة: 25-02-2014, 07:34 PM
  2. Downloading LandSat Imagery from USGS Glovis and Importing it into ERDAS Imagine
    بواسطة كريم مصطفى في المنتدى برنامج Erdas Imagine
    مشاركات: 2
    آخر مشاركة: 16-04-2013, 05:24 PM
  3. NASA | Earth Observing Landsat 5 Turns 25 Years Old
    مشاركات: 1
    آخر مشاركة: 21-03-2013, 03:42 PM
  4. Using ERDAS Imagine- to Layer Stack Landsat Images and Conduct Unsuprivised Classific
    مشاركات: 1
    آخر مشاركة: 13-01-2013, 01:33 PM
  5. Downloading LandSat Imagery from USGS GLOVIS and Importing it into ERDAS Imagine -- P
    مشاركات: 3
    آخر مشاركة: 13-08-2011, 12:32 PM
الكلمات الدلالية لهذا الموضوع
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
