مصر العراق السعودية سوريا لبنان الأردن اليمن ليبيا السودان المغرب تونس الكويت الجزائر البحرين الإمارات عمان موريتانيا الصومال فلسطين جيبوتي جزر القمر قطر باكستان اندونيسيا تركيا ايران ماليزيا
  • amazing_sunset
  • apple_tree
  • beutiful_landscape
  • birch
  • camomiles
  • cherry
  • in_the_forest
  • nature
  • spoondrift
  • stream
  • strobiles_on_spruce
  • sun_and_sea
  • jquery carousel
  • sunset_on_the_river
amazing_sunset1 apple_tree2 beutiful_landscape3 birch4 camomiles5 cherry6 in_the_forest7 nature8 spoondrift9 stream10 strobiles_on_spruce11 sun_and_sea12 sunset13 sunset_on_the_river14
slider html5 by WOWSlider.com v8.2
صفحة 1 من 2 1 2 الأخيرةالأخيرة
النتائج 1 إلى 10 من 14
  1. #1
    عضو مؤسس
    تاريخ التسجيل
    Jun 2011
    المشاركات
    62,794
    حمل الآن: ArcGIS (Desktop) 9.3.1 Service Pack 2
    حمل الآن:
    Installation Notes
    It is important to keep all versions of ArcGIS products installed on the same machine in sync to avoid any software conflicts.
    If you have installed client setups from a shared Network Administrative ArcGIS Desktop setup, Service Pack 2 must be applied to all client installations.
    ArcIMS and ArcSDE users:
    If you use ArcIMS 9.3.1 or ArcSDE 9.3.1, you must also install ArcIMS 9.3.1 Service Pack 2 or ArcSDE 9.3.1 Service Pack 2. For example, if you use ArcIMS 9.3.1 and ArcGIS 9.3.1 Desktop, install both ArcIMS 9.3.1 Service Pack 2 and ArcGIS 9.3.1 Desktop Service Pack 2. Since ArcIMS 9.3.1, ArcSDE 9.3.1 and the ArcGIS 9.3.1 products share common DLLs, it is important to keep the software release versions in sync to avoid any software conflicts.
    ArcGIS Desktop 9.3.1 Evaluation Edition users:
    Service Pack 2 is supported with the ArcGIS Desktop 9.3.1 Evaluation Edition.
    ArcGIS Server Post Install:
    The ArcGIS Server Post Install will automatically launch after the update has been applied. If this doesn't happen, please be sure to launch the GIS Server Post Install and Web Applications Post Install (if ArcGIS Server .NET is installed) manually from the shortcuts found in your Start menu. The GIS Server Post Install will prompt for the ArcGIS Server Object Manager (SOM), ArcGIS Server Object Container (SOC), the GIS Server Manager (on ArcGIS Server Java) and the GIS Server Webservices (on ArcGIS Server .NET) user accounts and their associated passwords. To avoid disrupting the operation of your server installation you will need to use the exact same accounts and passwords that you used when you initially installed ArcGIS Server (or the last time you ran the Post Install). If you don't remember which ones you used you can have the Post Install create new ones for you, but you will need to update the permissions on your data and non-default output server directories to grant access to the new ArcGIS Server Object Container (SOC) account. Additionally, if you previously had large caches associated with cached Map or Globe services it may take a very long time for the Server Post Install to alter the permissions on the large number of files in your caches (see Technical Article 32766 for a suggested workaround). For help on getting started after installing ArcGIS Server, refer to the Administering the server--*gt; Getting started after install topic in ArcGIS Server Help.
    ArcGIS Server for the Microsoft .Net Framework users:
    The ArcGIS Server for the Microsoft .Net Framework setup has a Service Pack 2 setup named ArcGISServerDotNet931sp2.msp. The 9.3.1 Service Pack 2 release also includes a setup for the Web Application Developer Framework (ADF) Runtime. This Runtime installation is installed on production machines where you plan to deploy Web Mapping Applications built with the Manager or the Web ADF. The ArcGIS Server for the Microsoft .Net Framework Web ADF Runtime setup has a Service Pack 2 setup named ArcGISServerWebADFRuntime931sp2.msp. You would only need to run the ArcGISServerWebADFRuntime931sp2.msp if you had run the separate Web ADF Runtime install when you installed 9.3.1 Final.
    A machine that has the ArcGISServerDotNet931sp2.msp installed would not require an installation of the ArcGISServerWebADFRuntime931sp2.msp.
    System Administrators - A technical paper is available that discusses the enterprise deployment of ArcGIS 9.3.1 setups using Microsoft® Systems Management Server (SMS) and Group Policy, including additional system requirements, suggestions, known issues, and Microsoft Software Installation (MSI) command line parameters. Deployment in a lockdown environment is also covered. ArcGIS 9.3 Enterprise Deployment.
    حمل من هنا:
    http://www.4shared.com/file/CBs35NqU...top931sp2.html
    تحياتي
    هيثم علوانى
    جوال: 966565573893+
    البريد: haitham.elwany@gmail.com
  2. #2
    عضو جديد
    تاريخ التسجيل
    Feb 2012
    المشاركات
    1
    يعطيك العافية مشكور
  3. #3
    عضو جديد
    تاريخ التسجيل
    Apr 2012
    المشاركات
    2
    شكرا جزيلا
  4. #4
    عضو جديد
    تاريخ التسجيل
    Sep 2012
    المشاركات
    1
    thanks ya man
  5. #5
    عضو جديد
    تاريخ التسجيل
    Sep 2012
    المشاركات
    1
    مشكووووووووووووووووووورين
  6. #6
    عضو جديد
    تاريخ التسجيل
    Dec 2012
    المشاركات
    1
    مشكوووووووووووووووووووووو ور جدا
  7. #7
    عضو جديد
    تاريخ التسجيل
    Jul 2012
    المشاركات
    1
    خالص تحياتى ومشكوررررررر
  8. #8
    عضو جديد
    تاريخ التسجيل
    Feb 2013
    المشاركات
    1
    [hhhhhhhhl]جامد جدا ربنا يوفقكم
  9. #9
    عضو نشط
    تاريخ التسجيل
    May 2013
    المشاركات
    47
    يارك الله بكم وجزاك الله خيرا
  10. #10
    عضو جديد
    تاريخ التسجيل
    Nov 2013
    المشاركات
    1
    GIS Tenders
    شكرا جزيلا
معلومات الموضوع
الأعضاء الذين يشاهدون هذا الموضوع
الذين يشاهدون الموضوع الآن: 1 (0 من الأعضاء و 1 زائر)
المواضيع المتشابهه
  1. كراك نسخة ArcGIS 10 Desktop
    بواسطة هيثم علوانى في المنتدى برنامج ArcGIS
    مشاركات: 102
    آخر مشاركة: 01-08-2017, 06:11 PM
  2. عاجل وحصري: تنزيل تحديث ArcGIS 10 Service Pack 3
    بواسطة المشرف العام في المنتدى برنامج ArcGIS
    مشاركات: 6
    آخر مشاركة: 25-03-2015, 07:49 PM
  3. 10 Getting to Know ArcGIS Desktop
    بواسطة شيماء جمال في المنتدى برنامج ArcGIS
    مشاركات: 17
    آخر مشاركة: 21-03-2015, 01:21 PM
  4. ENVI 4.7 Service Pack 1 Release
    بواسطة كريم مصطفى في المنتدى برنامج ENVI
    مشاركات: 3
    آخر مشاركة: 18-07-2014, 07:16 PM
  5. حصري ArcGIS 10 (Desktop, Engine, Server) Service Pack 2 - English
    مشاركات: 7
    آخر مشاركة: 24-09-2013, 02:51 PM
الكلمات الدلالية لهذا الموضوع
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
